Flow test from 2 shower heads - is 3 GPM sufficient?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by murphy290, Dec 2, 2013.
  1. murphy290
    murphy290 New Member
    Nov 29, 2013
    new york
    Our new shower will have a fixed shower head and a handheld, with a thermostatic valve and separate volume controls so that the shower heads can be used separately or at the same time. Both shower heads are rated at 2.5 gpm. We did ten-second flow tests and got 4 gpm at each outlet when turned on separately, and 3 gpm when they were both on at the same time.
    Are these results normal? Since we have more than 2.5 gpm, should we have enough volume/flow as time goes on?
    Thanks
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Why not double check your math.
    A larger bucket (like a garbage can) will give you a more accurate reading.
    Perhaps the flow restrictors are removed from the fixtures? 4 GPM is not a lot if your worried about flow rates down the drain and 4GPM is a lot if you are wanting lots of water. I would not freak out over these numbers.
    When flow rates get over 12-14 GPM you need to make sure the drain can handle it. Over 16-18 GPM and head water build up over the drains grate can measure as high as 1/2" in my private testing.
  4. murphy290
    Nov 29, 2013
    new york
    I should have explained - I didn't have the actual shower heads on the outlets, just a goose neck. (One shower head is still on order.) I'm more concerned that I won't have enough flow, so I wanted to check before we go any further in the remodel. Is 4 gpm for each when on separately and 3 gpm with both on normal?
    I can install one of the shower heads plus use an old one to do another test if that makes sense. What do you think?
    Thanks
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I would do that.
    To much water flow and you will need a larger hot water tank!
  6. murphy290
    Nov 29, 2013
    new york
    Yes - either a larger hot water tank, or we'll have to take very quick showers!
    Thanks again.
Similar Threads: Flow test
Plumbing Forum, Professional & DIY Advice Humidifier, testing water flow Sep 23, 2015
Plumbing Forum, Professional & DIY Advice Backflow test kit calibration Dec 3, 2013
Plumbing Forum, Professional & DIY Advice Backflow Prevention Testing Certification Jun 1, 2010
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
Plumbing Forum, Professional & DIY Advice Most Reliable RPP Backflow Model? Feb 10, 2017
