Flow Problem mystery with rear discharge toilet
Discussion in 'Toilet Forum discussions' started by FishAllThe Time, Dec 29, 2009.
  1. FishAllThe Time
    FishAllThe Time New Member
    Dec 29, 2009
    Orlando, FL
    I have a rear discharge toilet (Gerber) in an upstairs toilet above my kitchen in a home that is only 13 years old. (Not sure model but I found the following written inside the tank A-51 28-590). It is a 1.6GPF model. Due to the design of the house, the pipe in the wall behind the toilet is 6 feet long and is angled downward but only drops 18 inches (over the course of those 6 feet) before turning straight down in the wall.
    It always requires a double flush (even with no solids) and sometimes that is insufficient.
    The tank fills to the designated fill level. It empties in 10 seconds and appears to be emptying normally into the bowl. I have dismounted and checked the pipe behind the toilet and it is clear.
    What is the reason for the poor flushing? Is it the design of the toilet? Is it the low angle of the pipe in the wall? What is the best solution?
    Thanks for any help!
  2. Terry
    Aug 17, 2004
    I would guess that there is something in the trapway slowing things down.
    You may need to auger the trapway.
  4. FishAllThe Time
    Dec 29, 2009
    Orlando, FL
    I forgot to mention that augering it thoroughly as the first thing I tried. When that didn't work, I removed the toilet and visually inspected the discharge pipe in the wall as well as the toilet itself. I also used a wire and reamed out the small holes where the water flows into the bowl in case they were slightly plugged. I didn't find any plug anywhere. Still stumped. :(
  5. Terry
    Aug 17, 2004
    In less you are using an auger with a 1-3/8" head, you may still be leaving things in there.
    The common auger from a hardware store is only 7/8"
    They rarely do anything.
    However, if it never worked from day one, it could be argued that it's a bad bowl.
    I did install a pressure assist Gerber that was bad from the factory too.
Similar Threads: Flow Problem
Toilet Forum discussions Best toilet for a landlord wanting to avoid problems with toilet overflows? Jun 13, 2013
Toilet Forum discussions Toto Ultramax overflow problem. Oct 24, 2010
Toilet Forum discussions Flowise Dual Flush 2479.216 dual flush toilet, problems and questions Nov 6, 2008
Toilet Forum discussions Tips for Flowmastervalve problem? Sep 5, 2008
Toilet Forum discussions flushing problems w/ new American Standard 2073 Flowise High Efficiency Mar 7, 2008
