Flow control Ball valve, hot water baseboard
Discussion in 'HVAC Heating & Cooling' started by Vinijm, Apr 23, 2009.
  1. Vinijm
    Vinijm New Member
    Apr 23, 2009
    I have a question about flow direction vs ball orientation in a honeywell flow control valve. In the indicated flow direction on the valve body the synco motor has to close the valve against the water pressure. The valve is listed as normally open but unless it is installed against the arrow, the water pressure would not help to force the valve onto the seat. Shouldn't the water pressure be helping to close the valve, then the syncro motor taking the ball off the seat in order to open the water flow?
Similar Threads: Flow control
HVAC Heating & Cooling Monoflow system upgrade to combi Mar 19, 2017
HVAC Heating & Cooling Insufficient heat transfer fluid flow to swimming pool heat exchanger Nov 30, 2015
HVAC Heating & Cooling HVAC airflow design issues and measurement Aug 17, 2015
HVAC Heating & Cooling Water Overflow? Jul 21, 2014
HVAC Heating & Cooling HW monoflow loop Feb 22, 2013
