flow check valve + circulator or circulator with flow check integerated?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lmei007, Feb 3, 2014.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    I am in the position to make a decision to use a flow check valve plus a circulator or just a circulator which with an integrated flow check valve inside such as 007-IFC series. which way you will go?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Circ with check valve.
  4. hj
    when the check valve wears out or fails, it will be a lot cheaper to just replace a check valve.
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    Nope, it's cheaper and a whole lot faster to change the check valve in the circulator but, I've never seen one fail
  6. jadnashua
    Many (all?) of the Taco circulators use a cartridge to replace the wearable parts. Not sure what the relative costs are verses just buying a whole new one, but swapping the cart is certainly easy.
  7. hj
    we are referring to the "check valve" not the impeller cartridge, and if the check valve NEVER fails it must be the only "eternal" plumbing part in existence.
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    Maybe. I've been installing Taco 007's with the check valves since they 1st came out and I haven't had a single check valve fail yet. If you look at the design, I'm not sure how they could fail unless something wedged itself in there. Then again, I don't think I've had to replace more than one or two regular flow checks in 40 years either unless the packing leaked. Most can be "adjusted" when they stick open with a hammer to the side.
Similar Threads: flow check
Plumbing Forum, Professional & DIY Advice Flow Check Valve Adjustment Jul 2, 2015
Plumbing Forum, Professional & DIY Advice a separate flow check valve or a circulator with a flow check valve? Feb 8, 2012
Plumbing Forum, Professional & DIY Advice Are some checkvalves better than others - Water Backflow Preventer Sep 22, 2011
Plumbing Forum, Professional & DIY Advice Sump pump ball check/backflow valve. Sep 3, 2010
Plumbing Forum, Professional & DIY Advice Bathtub overflow linkage stuck Mar 18, 2017
