Floor joists near flange
Discussion in 'Toilet Forum discussions' started by gbh, Dec 22, 2008.
  1. gbh
    gbh New Member
    Dec 17, 2008
    Colorado
    I'm preparing to put down tile in a bath area, and I'm having to do a substantial amount of floor reinforcement. Yesterday I pulled up a bunch of plywood to box off sections, and was able to see a good portion of the plumbing. I noticed the toilet flange does not have floor joists on two sides (the left and right of toilet) as I was expecting. It's simply sitting in the middle of a section of plywood. The joists in the area it's in are on ~28" centers. It is nearly centered between these joists, so the flange center is about 14" to either of the two nearest joists (front and rear of toilet). I have to cut up this area and box it off so it will support tile, but what should I do about the flange? When I box it off, how close to the flange should I put the boards?
  2. hj
    flange
    The flange has nothing to do with the joists, headers, or anything else. The last thing carpenters are concerned about is where the toilet will sit so they can install a joist next to it.
  4. gbh
    gbh New Member
    Dec 17, 2008
    Colorado
    While building my house, I'm sure the only thing the carpenters were concerned with was "How long until beer-thirty?" Poke a hole in any wall/floor, and it is all but guaranteed you'll find a quality control issue. In any case, shouldn't there be additional support for a toilet rather than simply placing it on an open span of 3/4" ply? I'm going to beef up the area some in any case, I just thought there might be accepted standards.
Similar Threads: Floor joists
Toilet Forum discussions cleanout locations when pipe is between joists and up against subfloor Feb 22, 2012
Toilet Forum discussions Wall hung toilet or drill floor joists Jan 15, 2007
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
Toilet Forum discussions Floor mount rear outlet Barrington vs Yorkville Sep 16, 2016
