Floor drain in laundry room
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kd, Dec 16, 2006.
  1. kd
    kd New Member
    Dec 11, 2006
    Per Code, can I have a floor drain go into a P-trap and then drain onto the ground? The drain is for washing machine overflows and mopping.This was previously connected to the sewer and a back-up flooded the room with ugly sewage.
  2. Cass
    Cass Plumber
    Nov 12, 2005
  4. kd
    kd New Member
    Dec 11, 2006
    I want to have a floor drain so that a washing macine overflow will not flood the entire house. I just want to know if it is Code legal to have it drain into the dirt under the house.
  5. Terry
    Aug 17, 2004
    The floor drain to be legal needs to go into the waste system.
    It should also have a trap primer to keep water in the trap.
    The trap should be a 2" and needs to be vented to keep it from siponing dry.
  6. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Flr drain in laundry room
    How about putting a pan with a 3/4" discharge line under the WM and running it to the exterior of the house?
  7. kd
    kd New Member
    Dec 11, 2006
    What is the difference between a pan under the washer and having the whole floor be the pan? If you connect the drain to the sewer it becomes the lowest point, first area to flood. A shower pan is much easier to clean. Also what is a trap primer?
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Even if you had the washer drain into the dirt it would back up because there is no way, if when it backs up it is, "flooding the entire house" it could drain fast enough to handle the amount of water the machine would be dumping.
  9. jadnashua
    When a drain isn't used much, the water in the trap will often evaporate, leaving a hole into the sewer, allowing gasses to escape. In these cases, a pipe and special valve is used to to dribble some water into it to keep it "primed" so it can do its job of blocking the sewer gasses.
  10. kd
    kd New Member
    Dec 11, 2006
    I am planning on using using a screened shower drain with a 2 inch ABS pipe and a 2 inch trap. Should an overflow happen, I think that will handle the washing machine pump flow, assuming that the drain is not clogged with lint, etc. I presently have a 2 inch standpipe with a 2 inch trap in the crawl space. I have not had a standpipe overflow, but have had several "filling the washing machine tub" overflows. The fill level is regulated by an air pressure hose with no emergency over the top shut off switch. My macine is 2 years old.
  11. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    floor- or shower drain
    kd
    seems to me you keep asking two independent questions simultaneously every time.... every post confuses me.
    1. Yes, a floor drain is a good thing, and is way better than a pan. I have floor drains.
    A floor drain that is going to be used more than just for an emergency, is a shower drain. Needs waterproofing around it, on a slight slope too.
    Why waterproof? Otherwise your floor rots, even if it is made of concrete or tile, since dirty water percolates through grout and stagnates under the tiles, or percolates through the pores in the concrete, even if the concrete is sealed.
    Why on a slope? So water runs, trickles, slips and slides over to the lowest point, the drain. A shower drain is made to accept the bulk of the water through its visible top but also to receive a minute trickle of water that has worked its way under the floor's top layer of tile.
    btw, according to code a floor drain in a bathroom is to be waterproofed and sloped just like a shower drain.
    2. Whether you can officially or wisely send your drain water down into the ground, is a second concern. A different problem.
    I wouldn't do it.
    David
  12. stephanie43
    stephanie43 New Member
    Dec 26, 2006
    second floor laundry room drain
    I am building a new house and am trying to find out what the plumbing code requirements are (in Illinois) for:
    - is a drain required, either from a pan under the washer or in the room floor?
    - is a pan required under the washer, and if so, what do they look like and where do I get one? (The heating company made one of sheet metal, but with only a 1-inch lip, so doesn't look like it'll hold much water).
    Anyone know where I can find out?
  13. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Your local department of building inspections or the equivalent... if nothing else you can call the business license office and begin your search there.
  14. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Do you have a licensed, registered plumbing contractor doing the plumbing? He will know the local code, or ask the inspector.
Similar Threads: Floor drain
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Floor drain for softener Jan 29, 2017
Plumbing Forum, Professional & DIY Advice New floor drain questions Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Floor drains verses washing machine pan Sep 7, 2016
