Floor Drain in a Utility Room
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Solan, Jun 16, 2008.
  1. Solan
    Solan New Member
    Jun 15, 2008
    I have just solved my nagging pressure / leaking PTV problem and it got me thinking pro-actively about future leak protection. I'd like to install a floor drain in my utility room where my hot water heater is housed and run the PTV into the drain.
    Here are the specs:
    - It's approx 36" X 36".
    - It sits over a crawl space.
    - It's adjacent to the Master Bath (shower, toilet are with in 3' of hot water heater).
    My questions are:
    - How big should the drain line be?
    - Can I tie into the shower drain (possibly share the P trap?)
    - Or should it have it's own trap? (I'm concerned with the trap drying out).
    Thanks,
    -Solan
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think you'd have to have at least an 1-1/2" drain, maybe 2". It has to be trapped, and you're right about the trap drying out if not used. I don't think you can tie into the shower drain, but perhaps you could just run the pipe from the water heater to the shower and let it drain onto the shower floor.
  4. hj
    valve
    If the PTV is the heater's safety valve you cannot run it to the shower at all. If it discharged while someone was in the shower it could back up out of the drain and scald them, and the same thing would happen if it drained onto the floor, except then there would be no question about getting scalded.
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Consider putting a hole through the floor into the crawl space and running the 3/4" pipe from the valve into the crawl space. Terminate the pipe about a foot above the ground or just below the joists. Put a slip-on plastic cap, or a piece of plastic attached with tape, over the end so wasps and things can't build a nest inside. If the TPV releases water it will blow off or through the plastic into the crawl space.
    Seal the hole around the 3/4" pipe going through the floor.
  6. Solan
    Solan New Member
    Jun 15, 2008
    Okay if not sharing the shower P trap then would a floor drain (with it's own trap) be the answer? I like the idea of draining into the crawl space but the potential of 50 gallons possibly draining into the crawl doesn't really sit well with me.
    I guess I would need to "prime" the trap every once & a while to keep it from drying out. Would a 2" drain be the correct size? If so does anyone have a make & model in mind that might work?
    Thanks,
    Solan
  7. jadnashua
  8. Bob NH
    Oct 20, 2005
    New Hampshire
    You aren't going to ever get 50 gallons in the crawl space. The pressure aspect of the valve is set at 150 psi and the only way you get any significant amount at that pressure is if you have a source pressure of 150 psi.
    The usual way that TP valves open is if you have a regulator on the incoming line and no expansion tank (less than 1 gallon of leakage) or if the thermostat fails (very low leakage).
    If you have a pump and tank system that is a very large expansion tank and it usually has (should have) a relief valve that is usually set at 75 psi.
    You can make it as fancy as you want but it is not necessary.
Similar Threads: Floor Drain
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Floor drain for softener Jan 29, 2017
Plumbing Forum, Professional & DIY Advice New floor drain questions Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Floor drains verses washing machine pan Sep 7, 2016
