Floor drain back flow
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rayh78, Jul 22, 2009.
  1. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Want to replace a floor drain in a basement since already doing some concrete work. Looks like just a 2" line.
    I know there will be a P trap in the line. But is there a backflow valve.
    I have used check valves for other things. But it seems like a good idea to have one here so if main line ever backs up would not flood basement. But how could this even work since the floor drain would have so little pressure to open valve. If the flapper type is that weak it does not seem like it could work well.
    thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are two types of back flow checks that I know of. One is a swinging flap that is supposed to close if/when water rises in the drain. These don't really work well because over time dust and lint collect one the gate and when water rises slowly, they don't close. The second type has a ball that floats up and closes the pipe. These don't seem to be affected by the accumulation of lint and work quite well.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Backwater valves. The ball type are definitely the ones to go with. The one's I've seen "push" the sanitary a little lower by design so if pipe invert is an issue they may not be practical.
  5. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I have installed one of these in my basement floor drain.
    Let's the water out and stops water coming in.
Similar Threads: Floor drain
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Floor drain for softener Jan 29, 2017
Plumbing Forum, Professional & DIY Advice New floor drain questions Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Floor drains verses washing machine pan Sep 7, 2016
