flexible metal conduit/greenfield
Discussion in 'Electrical Forum discussion & Blog' started by solutions, Mar 21, 2008.
  1. solutions
    solutions New Member
    Mar 13, 2008
    After cutting the flexible conduit to length then putting the wire to be used in it - Is there not something they make that protects the wire from that raw cut edge of the conduit..? (a protective plastic type bushing insert,a grommet,maybe a fitting that has a protective type insert etc..) The romex cable to be used is 10/2 (hooking up a water heater)
    Much appreciated to all!
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Surely you cleaned up all the rough edges :eek:
    348.28 Trimming.
    All cut ends shall be trimmed or otherwise finished to remove rough edges, except where fittings that thread into the convolutions are used.
  4. Igor
    Igor New Member
    Dec 2, 2007
    Former Motorhome Electrician
    Oregon
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    He is using it to protect a cable from damage so the rules for installing the flex do not apply.
    If he wanted he could use a peice of water hose. It is being installed simply for protection.
Similar Threads: flexible metal
Electrical Forum discussion & Blog ground wire in flexible steel conduit - and a de-rating question Jul 26, 2013
Electrical Forum discussion & Blog Flexible Conduit? Sep 17, 2010
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Using Madison Clips with new work metal box Mar 14, 2015
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
