Flexible insulated duct
Discussion in 'HVAC Heating & Cooling' started by mannerofspeakin, Jan 20, 2009.
  1. mannerofspeakin
    mannerofspeakin New Member
    May 13, 2008
    House built in 1990. Need to replace a run of flexible duct work. The ductwork that needs replacing has a "9'" stamped on it next to its manufacturer information on the outside, which should mean 9 inch duct right ? I guess my trouble is that I can't find 9 inch flexible duct easily or at all. Any ideas ? This duct feeds three vents. Other ducts coming from air handler are this same size while others are 10 inch.
  2. MaintenanceMan
    MaintenanceMan In the Trades
    Dec 10, 2008
    Maintenance
    Indiana
    They do make 9" flex duct. You most likely will never find it at a home center though. Most likely you'll have to go to a supply house. You don't see 9" used very often. Measure the diameter of the pipe to make sure it is the correct size.
  4. mannerofspeakin
    May 13, 2008
    Thanks. It is 9 inches. Are there some ways to convert current opening to something more common ? Like an adapter or something ?
  5. MaintenanceMan
    Dec 10, 2008
    Maintenance
    Indiana
    Possibly, but it is probably 9" for a reason. Best to go back with that if it hasn't been giving you any trouble airflow wise.
Similar Threads: Flexible insulated
HVAC Heating & Cooling Flexible Duct in Narrow Crawlspace Sep 23, 2016
HVAC Heating & Cooling Extending a flexible duct Oct 19, 2014
HVAC Heating & Cooling Collapsed flexible tubing used for the drain line on the condensate pump Jan 15, 2013
HVAC Heating & Cooling How many take offs on a 10" flexible duct? Sep 19, 2011
HVAC Heating & Cooling 2 inch flexible aluminum duct vent available? Feb 25, 2011
