Flexible copper in hydronic heating systems
Discussion in 'HVAC Heating & Cooling' started by DAvid12846, Aug 29, 2010.
  1. DAvid12846
    DAvid12846 New Member
    Aug 29, 2010
    Upstate NY
    My Dad had a hydronic heating system put in in 1967. He had the contractor put the 1" copper pipe through a double 2"x10"x10' beam (attached as PipingNow.jpg). The beam in our unfinished basement is a supporting beam with two 4"x4" posts on either end. Next summer I want to replace the beam and have one end of a new beam tied into an unfinished interior wall in the basement. Over the years the house has been settling and the current beam is pushing down on the pipe :( . I want to reroute the pipe around the end of the beam. I have a couple of plans for rerouting the pipe.
    Plan "A" calls for moving 4 "force flow" tees and using two 45s and a 90 degree elbow (Attached as PipingPropA.jpg). I'd rather not move the tees and redo a couple of the 1/2" supply/return pipes. I'll ask about moving the tees in a future posting if I use plan "A".
    Plan "B" would not involve moving any tees, but I would have to use either four 90 degree elbows or flexible copper pipe with two 45 degree elbows (attached as PipingPropB.jpg). With this plan, I'm concerned that using too many additional elbows will cut down on the resistance of the flow of water. I'm leaning towards plan "B" and using 1" flexible copper.
    Any thoughts? Should I use flexible copper? Maybe wide radius 90 degree elbows instead?
    In advance, Thanks
    David
  2. DAvid12846
    Aug 29, 2010
    Upstate NY
    EEks! When I added the attachments, I told it "attachment" as opposed to "in-line". Looks like they're appearing "in-line"!
    Anyway, the photo under my posting is "PipingNow.jpg", my current piping.
    The next photo is Plan "A" (PipingPropA.jpg).
    The bottom photo is Plan "B" (PipingPropB.jpg).
Similar Threads: Flexible copper
HVAC Heating & Cooling Flexible Duct in Narrow Crawlspace Sep 23, 2016
HVAC Heating & Cooling Extending a flexible duct Oct 19, 2014
HVAC Heating & Cooling Collapsed flexible tubing used for the drain line on the condensate pump Jan 15, 2013
HVAC Heating & Cooling How many take offs on a 10" flexible duct? Sep 19, 2011
HVAC Heating & Cooling 2 inch flexible aluminum duct vent available? Feb 25, 2011
