Flexible Boot for Air Vent
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pwjhuber, Jan 16, 2008.
  1. pwjhuber
    pwjhuber New Member
    Jan 16, 2008
    I have someone who is installing a medicine cabinet. When he cut a hole in the wall, there was a cast iron air vent pipe blocking the site for the cbinet. His solution was to cut the pipe to remove the section that is in the way and then rejoin the pipe using a (rubber) flexible boot. My question is whether this will become a problem later. In fact, I have read that it is against code to install a boot behind a walll. Is that only in the case of water pipes? Does it also apply here for a vent? Is trouble on the horizon? Thanks.
  2. jadnashua
    Vent/drain pipes above ground can be joined with no-hub connectors. THese are neoprene rubber sleeves with metal reinforcement bands and all secured with hose clamps. If the fitting was just a thick rubber sleeve with clamps at the end, it is not to code.
    Air doesn't really care about the corners, but jogging it over will make it impossible to run a snake down if it ever got clogged by say a dead bird, mouse, squirrel, leaves, etc. Any horizontal sections need some slope so any condensation, melted snow, rain, etc., can drain without blocking the pipe.
    What you saw is one reason why many medicine cabinets are surface-mounted, or the wall is bumped out.
  4. pwjhuber
    pwjhuber New Member
    Jan 16, 2008
    Thanks. Actually the cast iron pipe is horizontal in this section too! I am mostly worried about the lifetime of the boot.
  5. jadnashua
    If the proper one was used, it should outlast the pipe.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Is this pipe truly a vent (air only) or, is it a drain line that has waste water run through it?
Similar Threads: Flexible Boot
Plumbing Forum, Professional & DIY Advice Water heater - natural gas - black iron rebuild with flexible CSST Feb 16, 2016
Plumbing Forum, Professional & DIY Advice Plastic or flexible dishwasher supply line Aug 13, 2015
Plumbing Forum, Professional & DIY Advice Flexible hose for connecting jet pumps... Mar 6, 2015
Plumbing Forum, Professional & DIY Advice Flexible supply line for clawfoot tub Oct 2, 2014
Plumbing Forum, Professional & DIY Advice is flexible drain kit appropriate for my kitchen sink? Aug 12, 2014
