flexable vent
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Giles, Aug 30, 2007.
  1. Giles
    Giles Retired tool & Die and Mechanic
    Aug 28, 2007
    Retired
    N.W. Alabama--Florence--
    Is there any possibilities of installing a flexable vent in a basement bath? I ask this because rigid venting will be quite involved with all the obstructions I have. I live in the county and codes are no concern, except I respect them and I try to do everything BY CODE. The run will be approximately 15'. Yes, I want to do this job right! THANKS
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I think the worst thing about flexible pipes are the ridges and valleys.
    You run the risk of condensation collecting in the valleys and is a breading ground for mold and mildew.
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I would have the same concerns. However, the semi-rigid aluminum flex vent that looks like flexible auto-exhaust tubing and is used as flue lining might be okay in-between pieces of rigid vent pipe used wherever possible.
  5. jimbo
    jimbo Plumber
    The problem is neither that flex material, nor probably any connector you could use to hook it up with, is approved for this use by a governig body like IAPMO
Similar Threads: flexable vent
Plumbing Forum, Professional & DIY Advice 3" abs flexable? Jan 4, 2008
Plumbing Forum, Professional & DIY Advice Flexable Gas Line or Black steel Dec 21, 2006
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Today at 6:24 AM
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Wednesday at 7:14 PM
