Flex Heads?
Discussion in 'Water Softener Forum, Questions and Answers' started by truckkerjoe, Jul 20, 2013.
  1. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    Hello to all,
    I'am trying to understand why there are so many softener heads for different types of exchange resins.I have a flex5600econimizer. that we are using with Ionac c-249 for a soluble manganese 0.236mg/l which isn't working,so I was thinking on using Filox or Pyrolox or Greensand? but from what we are reading,they have all have diff.set-ups(heads) Filox-r calls for a flex-2700 for a 10in x 54' tank and so-on!!But a also have a bran new flex-7000 not the s.l.x. model,(just filter head).
    Can I use either one?Anyways we need to save water(slow-well).What is best approach?
    How about Greensand with potassium permanganate will this use the least amount of water?
    My set-up now<well=softener=cistern=bladder=house. so softener regenerates oxidized cistern-water(not-soluble) if you can understand?kind of wanting it this way? Thanks to all who reply
  2. ditttohead
    Jan 9, 2012
    Ontario California
    Fleck, Clack, Autotrol all make different heads for different applications and marketing purposes.
    The 5600 will not work with Filox or Pyrolox. It can only handle approximately 7 GPM backash rate.
    If you have a 7000, it can easily handle Pyolox but do you have enough water to properly backwash it? Pyrolox and filox are typically backwashed at 12 GPM on a 10" diameter tank for 5 minutes every few days.
    If you have a cistern, you may have some better options. What size pump do you have feeding the house? How many GPM? Can you install the water treatment after the cistern?
    And, it is Fleck, not Flex. From the name Fleckenstein. Here is a nice article on Andy Fleckenstein. http://www.jsonline.com/news/milwaukee/49559287.html
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Here I was thinking Flex was some Chinese knock-off of Fleck.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
  6. ditttohead
    Jan 9, 2012
    Ontario California
    Freck is the Chinese knock off. :)
  7. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Where's that ::groan:: smiley when you need it?
  8. ditttohead
    Jan 9, 2012
    Ontario California
    Sorr, it was really hard to resist. :rolleyes:
  9. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    Thank-you Dittohead, Pump feeding House is (well half-horse) Pump feeding softener is jet-pump half-horse that is coming out cistern! then into 60gal bladder tank with 1in lines,anyways what about a greensand and KMn04 with a small air-aertion pre seeding this 5600 FLECK softener+ cistern,just want it clean! if nothing else yes I can install after dirty tank.
    I was told potassium P. need HOLDING Time?How long?
    What kind of PSI or MAWP will a 10'' diameter tank hold? with a aerator? THANK-YOU so much.
  10. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    Greensand??
  11. ditttohead
    Jan 9, 2012
    Ontario California
    What kind of budget do you have for your water treatment?
    I am not much of a fan of PotPerm.
    What flow rate do you have available?
  12. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    The budget isn"t a big deal? Ain't sure flow rate again half-horse in well that is on a timer that runs about 2mins ON THE HOUR,so i might get what 10gals each hour?The jet pump can/or will produce 60gals each time bladder calls for(60gal tank) This cistern will hold 400gals does this help? AGAIN Thank-you Sir.
  13. ditttohead
    Jan 9, 2012
    Ontario California
    Some ideas come to mind.
    A lot of companies use ozone in the cistern. If your cistern is modern and can handle it, you may want to consider that idea. Otherwise the simplest design is a Chemilizer water driven chemical injection pump or chlorine tablet chlorinator, contact tank, backwashing GAC system. These can be done for under 2000 and are a simple and proven design to work most every time.
Similar Threads: Flex Heads
Water Softener Forum, Questions and Answers Water sofetner flex connection: diameter? Dec 5, 2015
Water Softener Forum, Questions and Answers Water softener flexible connections Dec 5, 2015
Water Softener Forum, Questions and Answers Advise to remove a Flex control from tank and conversion from WS to Sediment Filter Sep 25, 2015
Water Softener Forum, Questions and Answers Flex 5600SXT Water Softener Control valve as a backwash valve? Jun 10, 2015
Water Softener Forum, Questions and Answers Replace kinetico heads with different style, possible? Apr 8, 2016
