Fleck 9100 Timer ID
Discussion in 'Water Softener Forum, Questions and Answers' started by sarrowsm, Jan 13, 2011.
  1. sarrowsm
    sarrowsm F5Scott
    Dec 3, 2010
    Engineer
    Brighton, MI
    Please help ID this Fleck Timer on 9100 Control Valve?
    Thank you,
    Scott
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    It is the 3200 timer run from Fleck, the one that you have does not have time, but rather gallons to trip it from one tank to the next.
    The frame that the parts are on is the same frame that is used for the timer one that will delay in gallon or day time trip..
    Set the gallons across from the white dot much like your old one.. if your old one was at 800 gallons then find the 8 on this one and set with the white dot..
  4. Old Fart
    Old Fart New Member
    Jan 13, 2011
    Retired
    Mi
    Pentair makes Fleck and Autotrol valves. PentairWaterTreatment.com, click on Fleck control valves. On the right side of the page, under Residential, is a list of Fleck & Autotrol valves. Click on a model number and it takes you to the spec sheets and the service manuals.
    I have about worn this sit out over the last week or two. Hope this helps.
  5. sarrowsm
    sarrowsm F5Scott
    Dec 3, 2010
    Engineer
    Brighton, MI
    Thanks for the help!
Similar Threads: Fleck 9100
Water Softener Forum, Questions and Answers Fleck 9100 SXT valve problems returned 60 days after replacing seals Feb 2, 2017
Water Softener Forum, Questions and Answers Fleck 9100SXT Regeneration problem Nov 17, 2016
Water Softener Forum, Questions and Answers Fleck 7000SXT or 9100SXT? Jul 27, 2016
Water Softener Forum, Questions and Answers Fleck 9100SXT programming question Aug 8, 2015
Water Softener Forum, Questions and Answers Fleck 9100 SXT Programming/Settings Mar 22, 2015
