Fleck 9000 settings question
Discussion in 'Water Softener Forum, Questions and Answers' started by Kurt Eric, Oct 9, 2009.
  1. Kurt Eric
    Kurt Eric New Member
    Oct 9, 2009
    Michigan
    Hello, purchsed forclosed home and it contains a fleck 9000 series water softener. It of course came with ZERO literature to tell me how to use!
    It seems to be working fine and I'm not having any problems with it other than it seems to using waaay too much salt! There are only 2 of us living in the house we just don't use that much water. Yet, I'm going through 6 forty lbs bags of salt every 5 weeks or so. Is this right?? Seems like alot.
    I've tried to figure out the settings/dials to adjust but don't really have a clue. Is there a simple way to adjust the unit for a slower rate of regeneration?
    If anyone could give me a couple of steps to try it'd be mucho appreciated.
    Kurt
  2. Gary Slusser
    Retired
    You need current water tests of the raw water (before the softener) for hardness, and if you have your own well, iron and manganese (if you can get a test for manganese and if not that's OK). Then you need to do some calculations based on your family size.
    Then you use the manual to program the control valve for the best salt efficiency for the capacity you need.
    To learn about that Click Here.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
  5. Gary Slusser
    Retired
    Kurt, no manual will tell you what capacity and salt dose you need or the volume of resin you have. And it will not get into salt efficiencies.
    Do you have the mechanical metered version or the electronic SE/SXT version? If your control is black plastic, you have a 9100; brass is the 9000.
Similar Threads: Fleck 9000
Water Softener Forum, Questions and Answers Fleck 9000 Piston replacement Dec 30, 2016
Water Softener Forum, Questions and Answers Fleck 9000 leaking Aug 16, 2016
Water Softener Forum, Questions and Answers Fleck 9000 leaking May 11, 2016
Water Softener Forum, Questions and Answers Corroded Fleck 9000 Valve Body Mar 27, 2016
Water Softener Forum, Questions and Answers Fleck 9000 problems Jan 19, 2016
