I have a 13x54 2.5 cu ft softener (80,000 grains) with a Fleck 7000SXT metered control valve on clean city water.
Can someone confirm the Brine Fill settings for me. Is it as simple as configuring C for 80,000 grains and BF for 25 (0.5 BLFC)? Or is that assuming 15 lbs of salt per cu ft and is that wasteful?
1: C Set to 80 (x 1000)
2: RS Set to SF
3: SF Set to 15
4: DO 30 (Max 30 days)
5: B1 Set to 10
6: BD 60 factory set, leave as-is
7: B2 Set to 5
8: RR Set to 10
9: BF set to 25 for 0.5 BLFC
I was thinking that I should use these settings which correspond to 10 lbs of salt per cu ft.
1: C Set to 63 (x 1000)
9: BF set to 17 for 0.5 BLFC
Or 6 lbs of salt per cu ft. Am I on the right track?
1: C Set to 50 (x 1000)
9: BF set to 10 for 0.5 BLFC
I'm not sure how smart the 7000SXT meter is and if it can optimize the regeneration by changing C and BF appropriately. What is recommended?
Thank you
2: RS Set to SF
3: SF Set to 15
5: B1 Set to 10
7: B2 Set to 5
8: RR Set to 10
Thank you
