Went up again to work on the softener with no luck...
Checked the resin:
Due to lack of time I ended up taking the electric controller off and moved the piston to the service position and had full pressure and softened water.
Replaced Spacers and Seals:
Replaced both spacers and seals and verified the piston moved prior to reinstalling the metal plate. Once the metal plate was installed, the piston wouldnt move at all. I couldn't move it manually at all and didnt even try it hooked up to the motor. Once I took the plate off, it moved. I pulled the new spaces and seals and replace the spacers with the old ones and reinstalled with the new seals and old spacers. Piston moved as it did before. Not sure what the issue was with those spacers but that seemed odd. I installed the controller and it went through the 1st and 2nd cycle ok. It didn't seem to pull all the brine in, but finished the 2nd cycle and went to the 3rd. Started off fine then seemed to lose water pressure again after about 2-3 minutes. Finished cycle 3 and went to the 4th cycle where it didn't seem to fill the brine level up to the previous level. I pulled the controller again (where it wasn't hooked up to the piston) and cycled through all 4 cycles to make sure the motor was working fine. It was. Reinstalled the controller and cycled through again not running the full cycle, but advancing the cycles but hitting the advance button. After the first run through I had water pressure, but not like when I first moved the piston to the service mode. Ran it again through all cycles and no water pressure again. Remove the controller and moved the piston to the service mode and had pressure.
I also had ordered a replacement motor and installed it. It didn't work (my luck) when I hooked it up. It hummed, but that was it as the gear wasnt moving. Installed the old one and worked as before. I tried the new one thinking the motor may not have the power to move the piston. Since it didn't work, I'm not sure but assume the old moves it enough?
Anyway,during the whole process I noticed the piston didn't move real freely and took a lot more pressure to move it than I though it should. Is that typical? I didnt replace the piston as it looks fine, but now I'm thinking it may need a new piston???
I also pull the brine screen, injector, and spring valve and cleaned them. No difference.
Not sure how to proceed now, with the exception of replacing the piston and maybe getting a replacement motor. The spacers and rubber seals were replaced in order (seal/spacer/seal etc). So I dont think that was the issue.
I'm at a loss and would appreciate any more ideas?
Thanks...
