Fleck 5600/Foregin Pieces in Cylinder
Discussion in 'Water Softener Forum, Questions and Answers' started by batman71, Dec 26, 2012.
  1. batman71
    batman71 New Member
    Aug 16, 2012
    My Fleck 5600 recently started jamming so I replaced the pistons, seals and spacers. The old ones were not in terrible condition. However, at the bottom of the cylinder I found three plastic pieces (photo below). I suspect that this was the culprit. What I am wondering is where these came from??
  2. Gary Slusser
    Retired
    I have no idea what those parts are or from.
    When you say "cylinder" I suspect you mean the resin tank. If so the parts couldn't have gotten up into the valve or cause problems unless they got down to the bottom basket and even then, that would maybe reduce a teeny tiny bit of water flow but that's it.
    There are other causes of a 5600 jamming and usually you can't see why by looking at the seals and piston, or brine valve.
    So does it work right now?
  4. batman71
    batman71 New Member
    Aug 16, 2012
    No, I did not mean the resin tank when I used the term "cylinder". I was referring to the housing that the piston assembly fits into. At the bottom, underneath the piston assembly, is where I found these pieces.
    The valve is working fine now...
    I think I just answered my own question...
    A couple of weeks ago, I had a problem with my well pump. I pulled the pump and discovered that the check valve, which is integral with the pump head, had broken. Here is a pic of the check valve....
  5. Gary Slusser
    Retired
    Yep, I think ya got it.
Similar Threads: Fleck 5600/Foregin
Water Softener Forum, Questions and Answers Fleck 40922 Monday at 1:43 PM
Water Softener Forum, Questions and Answers Fleck 5600sxt quit softening after sediment filter change Feb 18, 2017
Water Softener Forum, Questions and Answers Programming advice for Fleck 7000SXT Feb 12, 2017
Water Softener Forum, Questions and Answers Fleck 9100 SXT valve problems returned 60 days after replacing seals Feb 2, 2017
Water Softener Forum, Questions and Answers New Fleck 5812 SXT - Need help with settings Feb 1, 2017
