fleck 5600 econominder
Discussion in 'Water Softener Forum, Questions and Answers' started by rightlane, Dec 21, 2012.
  1. rightlane
    rightlane New Member
    Apr 2, 2010
    az
    hello all, i upgraded to a fleck 5600 econominder and have been happy for the last year, but it stopped working about a month ago. timer appears to not be keeping time at all and it won't manually regen. i replaced the timer motor and nothing changed. is there a way to check the transformer other than looking at the green light thats on it? thanks, chris
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Sounds to me like a bad control board but make sure the wires are all well connected
  4. rightlane
    Apr 2, 2010
    az
    the only wires are the timer and the transformer, right?
  5. ditttohead
    Jan 9, 2012
    Ontario California
    A digital volt meter is the correct way to check the transformer. Any common 24 v transfromer will work on that system, even a door bell transfromer, as long as it is 24VAC output. It should be able to supply 300mA. The led light is worthless, you have to check the actual output of the transformer. The motor has a tiny clear window on it as well that you can see if the motor has power, or you can put your ear to the valve and you will hear the motor turning. I assume you are referring to the actual 5600 econominder, the old school electro mechanical valve, no electronics.
  6. rightlane
    Apr 2, 2010
    az
    yes, the only wires i can find involve the timer motor. i hear and see nothing on either of the timers i have,. i will check for 300mA, thansk
  7. ditttohead
    Jan 9, 2012
    Ontario California
    Sounds like a bad transformer. look for a standard transformer, home depot or lowes should have them. 24VAC, 300mA or more mA will work fine.
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    Disregard my post. Wrong forum. I probably had a dozen windows open at the same time. This iPad is a pita lol
    Yes, transformer is probably bad.
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Actually, for this application the cheapest analog voltmeter in the world (often free) will work just fine to check for 24VAC. Something more exotic will be needed for measuring the current, since an AC current capability is rarely built in to a VOM, even a high-end device. They usually require an external current clamp-on adapter, and they're usually intended for higher-current applications. Measuring a small AC current is a very unusual application, judging from the availability of instruments to do it. I have an old Amprobe RS-2 which could do that; it's a clamp-on instrument, with an attachment to multiply the native 0-6A scale to 0-0.6A.The equivalent package today can be had for about $140. If I didn't have that, and I had to measure 300ma, I'd probably buy a 0-1A panel meter (under $10).
Similar Threads: fleck 5600
Water Softener Forum, Questions and Answers Fleck 5600sxt quit softening after sediment filter change Saturday at 6:08 AM
Water Softener Forum, Questions and Answers Need help tweaking fleck 5600sxt settings Jan 28, 2017
Water Softener Forum, Questions and Answers fleck 5600 what should happen in a complete proper cycle Jan 23, 2017
Water Softener Forum, Questions and Answers Fleck 5600 Timer Always Off Jan 14, 2017
Water Softener Forum, Questions and Answers Fleck 5600stx, having several gallons of rusty water after regeneration Dec 1, 2016
