MNO
I have a Fleck 2510 SXT, 64,000 grain capacity, with 18"x33" salt tank. I have replaced the entire brine fitting assembly (including the .5 GPM flow valve) and the 2310 float assembly. I checked all fill/drain lines for leaks and obstructions. Instructions call for 19 minutes of brine refill based on 64,000 capacity and 20 grains hardness. I timed entire operation and everything works as instructions dictate. However, the 19 minutes of brine refill ends up with far too much water in the brine tank. If left unchecked, it would fill the tank to near the overflow drain, but the 2310 float assembly shuts it off as it should. 9 minutes (as opposed to the suggested setting of 19 minutes) of brine refill puts the water level in the brine tank at about 16 inches. I cleaned everything suggested for brine tank overfill, then replaced everything with new parts after cleaning failed to correct the problem. Where do I go from here?
