Flat Panel Radiators
Discussion in 'HVAC Heating & Cooling' started by 1890farmhouse, Oct 10, 2008.
  1. 1890farmhouse
    1890farmhouse New Member
    Sep 5, 2007
    I plan to replace two cast iron radiators with Runtal flat panel radiators; one on the first floor and one directly above on the second floor. The existing hot water system has black iron pipe. What is the best way to connect new 1/2" copper for the flat panels into the black iron pipe? There is one set of Tees already connected to the supply and return lines for the existing first floor radiator. The second floor is a new room.
  2. jadnashua
    These threaded connections? If so, I'd screw in a brass nipple, then transition to the copper. The pros may have a better way.
    Adding a second panel, especially on a second floor, will probably mean you need to deal with balancing the flow...the lower one will get more heat since it will be harder to push enough flow up another flight. You may need some additional controls/valves to ensure both get enough flow to warm the rooms evenly.
  4. 1890farmhouse
    Sep 5, 2007
    Thanks for the info. They are threaded connections. I will probably add additional tees to the iron pipe to accomodate the upstairs radiator so it will have its own piping.
Similar Threads: Flat Panel
HVAC Heating & Cooling Cast iron vs flat panel rads Apr 13, 2016
HVAC Heating & Cooling flat panel radiators - mechanicals? Mar 5, 2008
HVAC Heating & Cooling Can Monoflow tees lie flat to floor joist or hang below Apr 27, 2010
HVAC Heating & Cooling Radiant Supply Panel Questions Dec 25, 2011
