Based on what I've read here, this may be a leaded connection to cast iron. So I don't think I should fool around with the current rusted but solid flange ring, even though it is bent in the left rear.
I believe I have seen it mentioned that a leaded connection the only time some would use the wax ring with the plastic horn/ring included. Optionally since it is a low flange, the use of two wax rings may be in order.
Any other suggestions/recommendations/comments?
Thanks.
Thanks.
