Flange too tall for new toilet
Discussion in 'Toilet Forum discussions' started by fishin49, May 13, 2008.
  1. fishin49
    fishin49 New Member
    May 13, 2008
    I recently remodeled our bathroom, replacing the damaged sublfloor and studs. After tiling, the floor is at the same height that it was when I started, flush with our hardwood floor in the hall. The flange is a little over 1/2" above the floor, which was ok for the old toilet. The new one won't reach the floor, about 1/8" short. I have an older home with cast iron pipes, what a pain!! Does anyone have an adjustable flange that will work with the cast iron? I see that Oatley does, but I think it's just for the ABS. Any ideas on how I can make this fit? Thanks.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't know how that worked with your old toilet, but it sure isn't the way a flange is supposed to be set. It is supposed to set on top of the finished floor, be anchored through the finished floor, and into the sub floor. Since you're dealing with cast iron, you should have a plumber remove the old flange and properly install a new one. You will have difficulty trying to do this yourself, but for a plumber, it will be a walk in the park. I advise you to spend the money and have this done correctly.
Similar Threads: Flange tall
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions How do I Install Toilet Flange to Stubbed Pipe in Concrete Slab Nov 20, 2016
Toilet Forum discussions Poorly installed flange Jun 11, 2016
Toilet Forum discussions Toilet Flange install question for 3" pipe May 28, 2016
Toilet Forum discussions Question on Aquia II install and unusual closet flange Mar 11, 2016
