Flange: "should" be level to tile floor???
Discussion in 'Toilet Forum discussions' started by BellevuePaul, Sep 23, 2005.
  1. BellevuePaul
    BellevuePaul Seasoned DIYer
    Sep 6, 2005
    Seasoned DIYer
    Bellevue, WA
    I was talking with a plumber that was quoting some work, and he suggested that if I'm installing tile, really it would be better to put my flange on top of the CBU, but level to the top of the tile, instead of on top of the tile. He claimed "it's just very difficult to get a solid base for the flange on top of tile."
    Um, *what*???
    The way I understand it, first of all floor tiles are pretty big relative to a CF, even 4x4" tiles there would be at most one seam on each quadrant of the flange.
    Further more, a flange is not structural, so as long as it's secured relatively solidly, and the toilet is otherwise mounted on a level floor, "rocking" has nothing to do with the flange.
    Finally, a lower flange means double wax rings or tall wax rings or other tricks that seem less certain than a single wax ring, and if it leaks, it leaks into the floor instead of on top of the floor.
    Is anybody interested in offering a credible viewpoint as to why this licensed professional might have been suggesting this approach???
    I'm certain what I intend to do, I'm just terribly curious to either disprove that this is the commonly accepted approach, or find out why that would be, if he was actually right.
    thanks...
  2. hj
    flange
    Well, he may be licensed but I question the "professional" part. Any reliable plumber who has been in the business for more than a couple of months knows the flange goes on top of the floor. That is the reason toilets have a space under them. The toilet fastens to the flange, but whether it moves or not is a function of how securely the flange is fastened, not how high or low it is.
  4. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Just finished tiling my new bathroom addition - then installing my flange on top of the tile.
    I spent quite a bit of time making sure my tile had "cutouts" for all 6 anchor holes (thank god for professional wet saws) - not wanting to try to drill through the tile after installed. - I seem to have bad luck drilling holes - even with the proper bit - in ceramics without them cracking....
    Maybe he didn't want to deal with the same issue?????
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flange
    HJ has it. On top is the only way.........
    The guy doesn't have much experience.
    I'm never too old to learn.
    Thezster, what kind if toilet needs slots for what kind of anchores?
  6. thezster
    thezster New Member
    Jul 18, 2005
    My toilet flange had 6 holes for anchors to the floor ringing the flange. I used all 6 with concrete screws....... The toilet itself anchored to the flange with the standard 2 bolts. Was that overkill? Toilet is secure... even my mother-in-law can use it without it moving... (get the idea?)
  7. jimbo
    jimbo Plumber
    I believe if your house is carried away by a tornado or hurricane, the toilet will still be standing.
  8. thezster
    thezster New Member
    Jul 18, 2005
    That was the general idea.... though my mother-in-law is a much bigger (get it) issue....
    (no honey, I didn't write that.... someone else must have my login I.D.) :D
  9. BellevuePaul
    Sep 6, 2005
    Seasoned DIYer
    Bellevue, WA
    Okay, that's what I thought!
    Thanks to all here for restoring my flagging sense of sanity! :)
Similar Threads: Flange should
Toilet Forum discussions Is Offset Toilet Flange Problematic And Should Be Avoided? Or OK To Use? Nov 23, 2015
Toilet Forum discussions Should I use a closet flange spacer ring - or just double the wax ring? Nov 6, 2015
Toilet Forum discussions Should I replace old flange Aug 1, 2015
Toilet Forum discussions Broken offset toilet flange - why is everything 10 times harder than it should be? Jan 8, 2012
Toilet Forum discussions What size toilet should I shop for 11 - 11.5"? Also flange anchoring question Dec 6, 2011
