Fixing threads in an old steam pipe elbow.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIYJP, Oct 30, 2008.
  1. DIYJP
    DIYJP New Member
    Oct 30, 2008
    I am fixing up some 1937 Warren-Webster in wall radiator valves that are leaking. These were converted from steam to hot water years ago. In the process, I came across a badly rusted 3/4" supply nipple that extended down into the floor that I felt needed to be replaced. I was unable to loosen it so I cut it off and dug the nipple end out of the elbow. As I have done before, I used a dremel to cut the inside of the bad nipple so I could collapse it for removal.
    Unfortunately, this time one of my cuts went completely through the threads perpendicular, top to bottom and I ruined the fitting. I have searched this and other places on the web and find that attempting twist off the old elbow will certainly only make matters worse.
    I found that a product like Harvey's Plumber Epoxy Putty supposedly can be used to repair threads and pipes but see mixed reveiws on how permanent it might be but none addressed my situation specifically. I got some and played around with it by using my dremel skills on a new fitting I made a new ruined fitting to test it. I then applied the epoxy and ran a tap through it once it hardened. It seems OK visually but I would like some expert opinons from those that have used this stuff. Perhaps this is the perfect application as it must be good for something.
    Lastly, I have just read a thread here (Steam Pipe Removal) that mentions cracking the old elbow off and replacing it verses trying to twist it off. Perhaps that is a better option but short of using a nut splitter I would have no idea how it is supposed to be done.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Two hammers. one backing, one striking. Be carefull. When you see the crack, stop hitting and twist it off.
  4. hj
    elbow
    It has to be a cast iron elbow to crack it off.
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If its an old steam system, it will be a cast iron fitting
  6. hj
    elbow
    99% of the time, but they could have used malleable on the smaller sizes.
  7. DIYJP
    DIYJP New Member
    Oct 30, 2008
    Thanks for your responses.
    Am I striking the end that is attached to the pipe or the open end? I do not want to damage the pipe threads. Will this break easily? I do not have much swing room because this fitting is down in the floor. I might be able to hold a 3 lb mallet under it and hit it with a small hammer. I like the idea of breaking the old elbow off but is the epoxy thread repair I described totally out of the question?
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Epoxy won't hold for long. Be carefull and take your time. When you see a small crack you should be able to spin the broken fitting off without damaging the nipple.
    May the force be with you.
  9. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Hit the hub of the cast iron elbow that is attached to the pipe , with the mallet firm up against the opposite side that you are going to be hitting.
Similar Threads: Fixing threads
Plumbing Forum, Professional & DIY Advice Prier Frost Free Faucet, fixing it? Oct 29, 2016
Plumbing Forum, Professional & DIY Advice Fixing Pipes in Basement Under Kitchen Sink Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Fixing tub drain / vent.. Sep 21, 2015
Plumbing Forum, Professional & DIY Advice Fixing Low Pressure in New Attic Bathroom Oct 31, 2014
Plumbing Forum, Professional & DIY Advice Fixing S-trap under kitchen sink Aug 7, 2014
