Aquila I and II vs III installation
Thanx Terry!
I am reading your excellent forum and i now see there are three models of the Aquia. Based on the photos you posted, that large plastic adapter on the model I must be what caused the noise complaints. I think i will look for the II; or III if i want an ADA compliant one. Since this installation will be for a guest half bath, an ADA model III might be a good idea.
What is the availability of a II or III model in bone?
None
Also, is that gray adapter for the II/III a replacement for a wax seal?
You still need a wax seal.
Checking the installation spacings, i see that Toto calls for a 12 inch setback and i have a good 12 1/4.
11-3/4" or more is good.
But, i only have 7 1/2 to the side of centerline of the drain to the outlet spigot as measured along the back wall and Toto calls for a 7 3/4 for the III. Considering some of the tight installations i have seen on your forum, will this 1/4 inch shortfall be an issue? Furthermore, the height of the spigot is 4 1/2 compared to the 6 inch recommendation; which may help considering how the Aquia III tapers toward the floor.
Aquia I, spacing can be 3" or more
Aquia II and III spacing can be 7" or more
Are there any other installation drawings available besides the two page pdfs from the Toto site?
Thanx
Tim
