Fittings for Shower arm
Discussion in 'Shower & Bathtub Forum & Blog' started by Planeguy9104, Jan 14, 2013.
  1. Planeguy9104
    Planeguy9104 New Member
    Jan 14, 2013
    Louisville, KY
    Remodeling my bath to install Moen IODigital vertical spa. I am going to use the shower head as an overhead rainshower, and the Handshower as the wall shower. To feed the rainshower, I am running cpvc up the inside of the plumbing wall, then using a 1/2 " x 24" chrome nipple across the ceiling (exposed), to a junction for the fixture. (Haven't exactly designed that yet...?)
    The question is about the transition from cpvc to the chrome and back at the fixture. I know that for pressure situations, I should use a transition union not an adapter, but is it necessary for the shower output. I was hoping to use a cpvc drop ear 1/2" weld x 1/2" FIP thread at the top of the rise and then a galvanized 1/2" street elbow at the fixture, for space savings.
    Any thoughts or other ideas. I am staying out of the attic because of difficulty reaching the edge and freeezing concerns. I could build a small soffit to cover the pipe, but that is almost as much trouble/$.
    Ted
  2. jadnashua
    Forget any galvanized piping - eventually, it will rust. Use a brass or bronze drop-ear...you do not want a female plastic fitting - they tend to split. For the short distances you're talking about, I think I'd use copper.
Similar Threads: Fittings Shower
Shower & Bathtub Forum & Blog Replacing bad shower drain fittings with new. Sep 22, 2014
Shower & Bathtub Forum & Blog Shower Panel-fittings question Dec 16, 2011
Shower & Bathtub Forum & Blog American Standard Shower fittings and faucets May 5, 2009
Shower & Bathtub Forum & Blog faucets, valves, fittings for standard tub/shower to roman tub/shower Sep 4, 2008
Shower & Bathtub Forum & Blog Shower Valve Inst - Male Threaded fittings or Unions? Jan 24, 2008
