Fitting Identification
Gordonk
Texas
I am in the process of trying to understand my cabin well/pump system. This system was installed in 1989.
Attached is a picture of the piping arrangement at my cabin well house. I am trying to identify the brass in-line fitting the pressure switch (PumpTrol) is attached to. What is it?
Cacher_Chick
Test, Don't Guess!
From what I can see it is a check valve that was designed to have a snifter valve installed in the side port. With a bladder tank, there is no need for a snifter valve, so the installer put the pressure switch there.
Gordonk
Texas
Thanks so much for the info. The thought entered my mind that it might be some type of a check valve. I had just never seen one with ports on it with a pressure switch attached. There is also a plugged port on the back side as you can see in this picture. I learn something new almost every day, I had to google snifter valve to see what one was, LOL. Thanks again. There is another check valve on the submersible pump, correct?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Ja, there would be a checkvalve in the pump. Depending on the height of the water table, if the lower checkvalve doesn't hold, the water column falls creating a near vacuum in the top of the pipe. When the pump starts, the column of water slams the topside checkvalve at full speed creating water hammer. A checkvalve holds better if it has pressure against it so the top checkvalve is more likely to hold than the lower one in that scenario.
