Fitting from pitless adapter to poly pipe leaking
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ohioguy456, Apr 27, 2009.
  1. ohioguy456
    ohioguy456 New Member
    Apr 27, 2009
    The fitting coming from the pitless adapter to the house is corroded & needs replaced. I'm guessing that if the fitting breaks off while trying to remove it I might be able to use an easy out or something comparable to remove the remnant (I hope). If I can remove the leaking fitting what is the best way to splice or reconnect the poly pipe to the new fitting. Problem is only 2 feet of poly pipe is uncovered & it is to stiff to flex onto new fitting. Any help is apprecaited.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Keep digging.
    bob...
  4. Gary Slusser
    Retired
    And don't break the male fitting off. Replace it with SS.
  5. BillH
    BillH New Member
    Mar 15, 2009
    Musician, Composer
    Reno, NV
    I've got the same problem. I've exposed 3-4 feet of the poly, and I'm wondering what's the best way to replace the corroded fittings.
    I posted some pictures:
    www.billhecht.com/images/DSC_0072.JPG
    www.billhecht.com/images/DSC_0071.JPG
    Assuming that it would be difficult to pull the barb out of the poly, I'm considering:
    1. Cut the poly before it goes into the barb
    2. Unscrew or cut the barb out of the Tee
    3. Unscrew the galvanized pipe nipple and Tee out of the pitless adapter and replace
    4. put a new SS barb in the remaining poly
    5. use a long galvanized nipple (and maybe a union?) to get to the new Tee.
    Is what I describe the right way to do this, or ... ?
    Thank you for your help!
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Tip:
    If you start to unscrew the fitting from the pitless and it starts to flatten out from the pressure of the pipe wrench. Get a 3/4" piece of galvanized pipe and put it inside of the 1". This will give it strength so you can reef on it with a wrench and get it to unscrew instead of flattening out and breaking off.
    bob...
  7. Gary Slusser
    Retired
    And while you're unscrewing the galvanized T stuff, hold the nut on the pitless so it doesn't turn. Do the same when installing the new stuff; don't use any galvanized. I would add enough PE pipe to make a natural curve into the pitless and use a SS male x insert and a coupler and double clamp all joints.
    You heat PE evenly, outside and inside, just quite warm to the touch and let it cool before clamping it.
Similar Threads: Fitting pitless
Pumps and Tanks Well Forum & Blog. Water is life. Pitless Adapter Fitting Question Friday at 11:31 AM
Pumps and Tanks Well Forum & Blog. Water is life. Wire or Tube from Switch to a Lower PVC Fitting May 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Park quick disconnect fittings Apr 28, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Looking for fitting Mar 17, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Preferred Well Head Fittings? Feb 21, 2015
