First time installing dishwasher, elbow connection question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dfresh4130, Oct 11, 2009.
  1. dfresh4130
    dfresh4130 New Member
    Oct 11, 2009
    Kansas
    Just put in a new GE dishwasher to replace an old one. First time I've done this and I've gotten to the point where it said get a 90 degree elbow with ferrule and compression nut. Now when I look at the hot water hose that's already there it's about 3/8" hard rubber with the end connecting to the elbow being molded with a nut already on it that can't be removed. Can I just install the new elbow and reuse the old nut? The elbow I bought has a small brass piece that goes in the end where the nut connects, but I can't put it in with the old hose. Is that absolutely necessary or will I have any problems if I don't put it in?
  2. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Replace all the old parts. If you have to cut a bit into the wall, do it. It will save you the hassle of leaks or other repairs later.
  4. hj
    hose
    If the old connection fits the new elbow you can reuse it, but a better way would be to replace the entire hose if it is rubber or plastic.
Similar Threads: installing dishwasher
Plumbing Forum, Professional & DIY Advice Installing a Samsung Dishwasher with existing Johnson Tee Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Installing new dishwasher Mar 20, 2015
Plumbing Forum, Professional & DIY Advice Help Installing New Dishwasher Dec 28, 2013
Plumbing Forum, Professional & DIY Advice Trick installing dishwasher motor & gasket? Apr 30, 2013
Plumbing Forum, Professional & DIY Advice Installing new garburator, dishwasher hookup Nov 19, 2010
