Fireplace backdraft
Discussion in 'HVAC Heating & Cooling' started by rockycmt, Feb 16, 2010.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    I have a very tight log home in the mountains of Upstate NY. When I light a fire it seems to draft well. Once it dies down the slightest wind outside overpowers the smoldering abbers and causes a backflow of smoke and soot into the house. Opening a window makes it even worse. What are my options?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Add 5 feet to the stack to give it better draft, and top it with either a venturi-type or whirlybird-type wind turbine so that even the slightest wind gives it a stronger draw instead of a backdraft. These people have a decent selection of vent turbines, etc., but they have plenty of other competition. If you're going for a whirlybird sure to pick an all-metal version (some have plastic bearings) if it's to be used on a chimney.
    If it's next to a gas or propane flue in the same chimney you need to go stainless or it'll corrode quickly, otherwise copper or galvanized both work for wood-fires only.
    I prefer lower-performance but lower maintenance venturi types myself. Too much suck and you de-pressurize the house, increasing outside air infiltration. Something that looks like these is usually enough to make a difference, along with a few feet of extra stack:
    [​IMG] http://www.bbsheetmetal.com/images/products/535/p535.jpg
Similar Threads: Fireplace backdraft
HVAC Heating & Cooling Gas fireplace shutting off Dec 22, 2016
HVAC Heating & Cooling Gas fireplace blower installation Nov 5, 2015
HVAC Heating & Cooling Fireplace removal Apr 9, 2014
HVAC Heating & Cooling Testing Gas Fireplace Dec 12, 2010
HVAC Heating & Cooling Can We Start a "FIREPLACE" Segment in the Forums? Dec 7, 2010
