Fire Rated Ceiling- Condo
Discussion in 'Remodel Forum & Blog' started by KULTULZ, Oct 15, 2008.
  1. KULTULZ
    KULTULZ Jack of all trades, Master of none
    Nov 13, 2006
    ROCKVILLE, MD
    I am remodeling a condo (daughter's) with a fire rated ceiling (Type X fire rated drywall hung on metal channels-sound suppression) with protruding fire sprinkler heads.
    I have opened a ceiling and after studying the system, am thinking about going to QuietRock over the channel system.
    The fire sprinkler estucheons. Are they removable to be able to apply new drywall? I have been told that they merely clip to the head and can be pulled down. I understand I will have to shim the overhead joists to get to the origional depth so as not having to shutdown the system and replacing the heads.
    Any insight here? Thanx!
  2. KULTULZ
    Nov 13, 2006
    ROCKVILLE, MD
    Found my info-
  4. hj
    heads
    The fire suppression heads MUST have the proper projection, meaning exactly the same as originally, from the finished ceiling to provide the proper spray pattern.
Similar Threads: Fire Rated
Remodel Forum & Blog HVAC duct through a fire rated wall May 29, 2011
Remodel Forum & Blog Fire-rated pull-down stairs into attic above garage Apr 29, 2008
Remodel Forum & Blog Basement closet wall with foam needs drywall for fireproof? Jun 4, 2016
Remodel Forum & Blog Advise asked on basement wall insulation and fire blocking Jan 15, 2015
Remodel Forum & Blog How much of the old fireplace can I remove? Aug 19, 2013
