Fire Pit on top of Septic Field?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DarkNova, Jul 22, 2009.
  1. DarkNova
    DarkNova New Member
    Mar 29, 2007
    Wisconsin
    We're looking at building a fairly small (~ 2 ft inside diameter) brick fire pit in our backyard. The ideal place would be the corner of the yard that happens to have the septic field under it. Would this be a problem? The 2 issues I can think of are the weight and the heat, but I am under the impression that the septic field is several feet deep and I wouldn't think either of those factors would be able to penetrate that deep, but I could be wrong. Or maybe there's another reason I cannot think of right now. The fire pit would not be used very often -- once every couple weeks at most and probably not even that. Any opinions? Thanks.
  2. hj
    fire pit
    A fire pit over the seepage field has no problems. Putting it over the septic tank would not be a good move.
  4. DarkNova
    DarkNova New Member
    Mar 29, 2007
    Wisconsin
    Yes, I meant that the pit would be on top of the seepage field, definitely no where near the septic tank itself. Thanks.
Similar Threads: Fire Septic
Plumbing Forum, Professional & DIY Advice Idiots and fire. Soldering in a wall Jan 11, 2017
Plumbing Forum, Professional & DIY Advice Liquid Fire drain cleaner question Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Fired for hiring a black plumber Jan 4, 2017
Plumbing Forum, Professional & DIY Advice SureStor Indirect fired hot water heater 120 gallons Oct 25, 2016
Plumbing Forum, Professional & DIY Advice Fire sprinkler alarm problem since water softener install Oct 8, 2016
