Fire Hazard? Expanding Foam - Electric Boxes
Discussion in 'Electrical Forum discussion & Blog' started by molo, May 8, 2009.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Is there a fire hazard created when you put expanding foam around electric boxes? What, if anything, is safe when using the foam around a box?
    Thanks for any replies:)
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Supposedly foam is fine around boxes. Just make sure all holes are sealed so the foam does not enter the boxes.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    In that case heat dissipation from the box due to I²R loss and bad wirenutting/connections depends on heat conduction through the copper and the cover plate being at room temp. I guess the NEC has already figured the boxes would be insulated with no air flow around them.
  5. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I have never heard of "heat dissipation" around electrical enclosures being an issue.
    A failed connection just need to be contained for safety.
    I would say the NEC definitely has considered this assuming many boxes and enclosures are on exterior walls and ceilings.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    I guess that means that enclosures have, or the air in them has, never gotten to 120 °C :D
    "Wood slowly chars [at] 120°-150°"
    but failed connections certainly have
    "Electrical arcing [up to] to 3750°[C]
    I guess air is pretty good thermal insulator.
Similar Threads: Fire Hazard
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog electronic ignition fireplace won't start when lights are on Mar 7, 2014
Electrical Forum discussion & Blog Firewall Outlet Box Placement(s) Jul 14, 2011
Electrical Forum discussion & Blog Force of Air Moved by Fireplace Blower Jan 20, 2011
Electrical Forum discussion & Blog Would There Be A Fire? Dec 20, 2010
