Fire block caulk around pipes - where and what kind?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by techinstructor, Oct 9, 2011.
  1. techinstructor
    techinstructor New Member
    Apr 24, 2009
    North Carolina
    I have questions as to where fire block caulk is required around pipe penetrations. Can someone answer yes or no to the following locations:
    * joists?
    * blocking (between joists, over basement load-bearing wall)?
    * subfloor (from basement to 1st floor and/or 1st floor to attic)?
    * sheathing for roof?
    My next question concerns compatibility with Pex. I have 3M Fire Block caulk. It was recommended by the salesman at the plumbing store (not a big box store) as what the plumbers use.
    Viega Pex says this in their literature:
    I can't find any list of these fire stopping compounds at the Viega site and the 3M Fire Block doesn't say any of these three words, "waterbased, acrylic or latex." I guess I could call Viega and/or 3M to find out more. If the 3M isn't compatible, does anyone have a suggestions as to what will work with both Pex and PVC (my DWV piping)?
  2. techinstructor
    Apr 24, 2009
    North Carolina
    I'm bumping this in hopes of getting a response. If you're not familiar with the 3M product, I'd still like to know what you use as fire stop sealant that is compatible with Pex. I can check with my inspector as to where it has to be applied.
    Thanks
  4. jimbo
    jimbo Plumber
  5. techinstructor
    Apr 24, 2009
    North Carolina
    Jimbo, I'm getting an error message when I click on the link. Can you try pasting it again?
    I found a document on the 3M site concerning CPVC, but like you I couldn't find anything specifically addressing Pex. I'm still looking for information.
    Thanks
    try this: http://solutions.3m.com/wps/portal/...HHD0IAH52Q9618R7_nid=W40MW3JMVNbeTGS9R7QM25gl
    If the forum somehow blockse the link, just google 3m fire barrier sealants
    Jim
  6. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    I've used the Great Stuff fireblock spray foam, and I think it's easier to apply than caulk (especially in tight places). The safety data sheet doesn't mention any incompatibility with pex.
  7. techinstructor
    Apr 24, 2009
    North Carolina
    Update on fire block
    I called Viega today and asked them about the caulk. They emailed me a short list of fire block/barrier sealants that are compatible with Pex. I'm attaching it here in case it could be of help to someone else. View attachment TA PEX firestops_1010.pdf I also found that this 3M product is sold at Lowes.
    BTW, the Viega tech support rep told me that the Great Stuff fire block foam was NOT compatible and should not be used with Pex.
    The whole issue of compatibility of materials seems to get more and more complicated as people use more and more artificial substances and the formulas get changed/improved in order for products to remain competitive. It's frustrating for the consumer and I'm sure it must also be frustrating for the manufacturer and the installers as well.
  8. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    "BTW, the Viega tech support rep told me that the Great Stuff fire block foam was NOT compatible and should not be used with Pex."
    That's good to know. I've never run pex before, but I'll make sure not to use that foam.
Similar Threads: Fire block
Plumbing Forum, Professional & DIY Advice Idiots and fire. Soldering in a wall Jan 11, 2017
Plumbing Forum, Professional & DIY Advice Liquid Fire drain cleaner question Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Fired for hiring a black plumber Jan 4, 2017
Plumbing Forum, Professional & DIY Advice SureStor Indirect fired hot water heater 120 gallons Oct 25, 2016
Plumbing Forum, Professional & DIY Advice Fire sprinkler alarm problem since water softener install Oct 8, 2016
