finishing basement???
Discussion in 'Remodel Forum & Blog' started by wfhjr1976, Jan 7, 2008.
  1. wfhjr1976
    wfhjr1976 New Member
    Jan 7, 2008
    what are the measurements for framing a wall off the centers of each pipe in my basement? i also have a large round plastic cover in the concrete floor and was wondering what that was for? if i could have finished measurements off the drywall id appreciate it. i have a 4 inch pipe, and it looks like 2 2 inch pipes. 1 of the 2 inch pipes has a square in the floor around it with dirt surrounding it like the concrete wasnt poured around it totally.
  2. jimbo
    jimbo Plumber
    Not exactly sure of your question. Drywall comes in 4'X8' sheets. Is that a question? As far as framing, 2X4 studs are 3½". 4" pipes do not fit in 2X4 walls. 3' plastice pipe just squeezes in, but fittings and hubsdo not.
  4. wfhjr1976
    Jan 7, 2008
    no,im wanting to frame some walls and need to know how far does the finished wall need to be from the center of my pvc pipes stubbed up in the floor. im not wanting to put them in the wall, i want to frame up for a bathroom and the pipes are already stubbed up in the concrete
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    If you want help you're either going to have to be clearer with your questions or provide some pictures. I read your post before Jimbo and ignored it because I couldn't understand your questions.
    Tom
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    If you're concerned about the waste line for the toilet, 12" from the finished wall is pretty-much standard. Supply lines and other waste lines are usually in the wall, shower and bath depend on configurations. A picture and/or diagram of what you've got and what you want would be worth a lot of words.
  7. wfhjr1976
    Jan 7, 2008
    basement
    i dont feel a picture would help much. i have a big room in my basement with pipes stubbed up for a bathroom, im wanting to frame that big room into a bathroom and a bedroom. but im not sure where to frame my wall cause of the pipes. whatever measurements the wall needs to be off the center of each pipe determines where i put the wall and thats the measurements im asking about. how far off a finished wall does each pipe need to be to the center of the pipe???
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I really can't say much more than I already have. I find it hard to believe someone stubbed up the lines without some idea of the ultimate bathroom layout.
  9. jadnashua
    As stated, a 'standard' toilet drain is 12" from the finished wall and needs 15" minimum on each side. A tub drain is wherever the silly thing ends up, as there are tubs with end, center and side outlets not counting the huge number of sizes. A shower drain ideally is centered in the area set aside for the shower. The drain lines for the vanity should be cenetered in the wall directly behind the sink. None of the pipes you have may be where your really want them, so see what you have, and selection of tub/shower might work, and if you can't compromise, then move them.
Similar Threads: finishing basement
Remodel Forum & Blog Finishing basement - 1 inch of height to spare for all flooring Dec 17, 2015
Remodel Forum & Blog Basement finishing - stud estimation Nov 25, 2015
Remodel Forum & Blog Finishing basement: Floor and Walls Jan 27, 2015
Remodel Forum & Blog Walkout basement finishing - insulating walls above and below grade Sep 9, 2014
Remodel Forum & Blog Finishing Basement - Insulating Walls and Floors May 16, 2013
