Hi,
I finished our basement about 7 years ago. There is a utility room that has the FHA gas furnace, a 50 gal gas hot water heater and it has a floor drain. The AC cooler unit condensation drain is piped to drain into the floor drain. Several times over the past few years the main sewer line has slowed or backed up and, of course, overflowed at the floor drain soaking the carpet outside of the utility room and creating a mess. I assume the drain is required in case the hot water heater leaks and for the AC drain.
Is there any solution that would reduce the risk of water backing up into the basement. Is there a device that can prevent backflow into the basement but still allow it to act as a drain during normal operation?
Thanks,
Gary
Thanks,
Gary
