Final adjustment of CSV Valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by royerm, May 14, 2011.
  1. royerm
    royerm Member
    Jul 14, 2010
    Quebec, Canada
    Well, if seeing is believing and doing is understanding, I'm almost there.
    Installed the CSV1Z with a new 6 Gals (1.6 Gals draw) bladder type tank, what
    a difference compare to my previous 35 gals.
    The pressure switch is set at 40-60 and I have set the CSV at 55.
    I ran a few test with 3 taps, 1 shower, 1 toilet flush giving me a flow of 9.4 GPM
    and holding it steady at 55......truly amazing and a delight.
    Reading the instruction, it suggest to bring the cut-In (ON) equal to my CSV pressure??
    I'm not sure about this one.
    My pressure switch can raise both(cut-in/cut-off) or the cut-off only but not the cut-in alone.
    Rising the cut-in to 55 would bring the cut-off to 75, which for some reason I find a little high!!??
    When the pump start it goes from 40 to 55 in a flash and once I shut the water off it takes about 15 seconds to bring it to 60 (shut-off).
    I've read somewhere I think that the pump should run for a minute????
    Do I keep it the way it is or rise the cut-in?????
    Regards...
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    I'd raise the cut-out setting to 60#. I'm sure that valveman will give you a better answer tomorrow.
  4. royerm
    royerm Member
    Jul 14, 2010
    Quebec, Canada
    from previous post...
    Will wait for Valveman...thx
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    With that size tank is is best to have the CSV set in the middle of the pressure switch setting. So just turn the large adjustment screw in the pressure switch to the right about 2 full turns. This will get you to a 45/65 setting, which will give you a little longer run time before the tank if filled. After turning off all faucets, you want at least 30 seconds but no more than 2 minutes of run time before the pump shuts off.
  6. royerm
    royerm Member
    Jul 14, 2010
    Quebec, Canada
    Okey dokey....will do.
    I'm really enjoying this setup and got convinced going that route by all
    the good information on this site...
    Cheers
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    Please give us a comparison of what you think about the CSV sytem compared to the old system.
  8. royerm
    royerm Member
    Jul 14, 2010
    Quebec, Canada
    I definitely get no fluctuation in the shower where with the old system I could tell when it was time for the pump to start to get the pressure back. Now I can flush a toilet or open another tap upstair and not earing a scream from someone in the shower.
    The amount of water being delivered seems illimited, of course as long as I'm within the limit of the pump.
    As previously stated
    "I ran a few test with 3 taps, 1 shower, 1 toilet flush giving me a flow of 9.4 GPM
    and holding it steady at 55......truly amazing and a delight."
    Voila...
  9. royerm
    royerm Member
    Jul 14, 2010
    Quebec, Canada
    2 turns and now at 45-65Psi...thx
Similar Threads: Final adjustment
Pumps and Tanks Well Forum & Blog. Water is life. Finally found driller's report for my well--question about casing Feb 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. pressure gauge finally reading 60, but the tank is reading 60 Mar 9, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Final FINAL installation pictures of cross, control valve, pressure tank, and pump! Dec 5, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Final (Hopefully) installation pictures of cross, control valve, pressure tank, pump Nov 16, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch adjustment Oct 2, 2015
