Yar02169
My irrigation well has always had a silt problem. With the help from this place, I've come along way, learned a lot, have a functional system now. Just a final question.
The silt isn't always, but enough to clog sprinkler heads. My solution was to install a Whirlpool 10" whole house filter (with the cheapest corrugated filter). I usually get two seasons out of the filter, and the system works fine.
Last year I had a pump issue, so I upgraded from my old Flotec to a Goulds pump. The silt would do a job on the pump, and I would have to replace the impeller now and again. Considering the cost of the new pump, I would like to relocate the filter, from after the pump, to before it.
That is where the questions start. Can the filter deal being on the suction instead of pressure side?
The draw pipe is 2" and the filter is 1", will that cause any issues? There is a 1.5" version filter out there, which would reduce issues, if any, but would it be usable as well? The filter is currently installed in-line on 1.5" pipe.
Just wondering if should leave well enough alone, or can I improve things.
