Filter moved
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by kd, Jan 28, 2007.
  1. kd
    kd New Member
    Dec 11, 2006
    After reading this forum, I have moved my whole house filter to the house side of the pressure tank. It works the same but I feel better about it now. I use a re usable filter because I get lots of rust in my water. About half a cup of rust per month. I also have a filter at the sink.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What do you think this whole house filter is doing for you?
  4. Rancher
    Rancher Guest
    Bob, It keeps whole houses out of the plumbing, I use one and have never had a house squirt out of my faucet yet... OK I only use it on the drinking water line, the rest of the plumbing is not filtered, just softened.
    Rancher
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Well at least now I know there really is a useful reason for installing one. Thanks Rancher.
  6. kd
    kd New Member
    Dec 11, 2006
    Without the whole house filter, we get rust colored ice in the ice maker. Also I can taste the rust in the shower. Also, previously, our water slowed to a dribble because we had a log jam of mangnaese ? in the pipes. Hurray for the whole house filter!
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I don't think you understand what that filter is doing/not doing. The filter is catching chunks of iron and maybe manganese from your plumbing. It is not removing iron or manganese. It can't remove them because it isn't desinged to. Backwashable filters with the correct media in them which are designed to remove these minerals are the only thing that will remove them. These filters are far larger than your in line filter also.
    If you can't taste the iron because of the filter, you may have a carbon filter, otherwise the taste would still be there too.
    bob...
Similar Threads: Filter moved
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water Filter Design Oct 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well to pressure tank to whole house filter to Jun 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Iron Filter On Water Well Help Apr 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. 50 micron prefilter plugging up way too fast Apr 19, 2016
