Fill Whirlpool through jets???
Discussion in 'Shower & Bathtub Forum & Blog' started by kcooper04, Dec 29, 2007.
  1. kcooper04
    kcooper04 New Member
    Dec 29, 2007
    I'm installing a whirlpool and do not want to have a tub spout poking me in the back when I'm relaxing, so I am considering adding a tee into the 1" line that is connected to the jets and piping the tub fill to to the tee so that the tub is filled through the jets. I have a Neptune tub and there is also an air line that connects to each of the jets. Is this going to work or should I consider something else? Thanks for your advice and help.
  2. Terry
    Aug 17, 2004
    Plumbing code requires a 1" air gap between the filler and the flood level of the tub.
    Any inspector that saw that would turn the job down.
    The reason, is cross contamination.
    You could wind up pulling your bath water into the water supply that you and your family drink, if the water is ever shut off for any reason.
  4. kcooper04
    Dec 29, 2007
    What if I installed a backflow preventer? I know that MTI has a Fill-Flush system with an air gap on top. Would a similar system work? or are there other problems to be concerned with?
    Thanks
  5. hj
    tub
    Or contaminate all of your neighbors' drinking water if the city shuts off the water because of a break.
  6. hj
    fill
    We don't know how that system is constructed or if you would use it or one of your own devising. There are lots of spouts for spa tubs that do not have to be mounted where they would be sticking you in the back.
Similar Threads: Fill Whirlpool
Shower & Bathtub Forum & Blog Whirlpool tub used with deck mount tub filler and hand shower Jun 25, 2010
Shower & Bathtub Forum & Blog Filling in a Roman Tub Feb 2, 2017
Shower & Bathtub Forum & Blog Hello everyone. Filling a tub Sep 22, 2015
Shower & Bathtub Forum & Blog Roman tub filler trims for Kohler K-300-K rough-in? May 21, 2015
Shower & Bathtub Forum & Blog Filled up pool now well water has an oder and odd taste. Aug 20, 2014
