Fill Valve Spraying Tank Lid
Discussion in 'Toilet Forum discussions' started by molo, Sep 5, 2012.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The Fill Valve is spraying out of it's top. It hits the tank lid and drips out onto the floor. Is there an adjustment that can be made to prevent this?
    Thanks in Advance,
    Bill
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Yes. But give us more info so we can help.
    Do you know the make and model of the toilet? The type of fill valve? Can you post a photo?
  4. Terry
    Aug 17, 2004
    Some fill valves will drip downward during refill. Spraying up and onto the tank lid isn't going to work well for you though. Are you sure it isn't an unused port for the tube that refills the bowl through the overflow tube?
  5. jadnashua
    Look closely at the tube going to the overflow, and make sure it is fully inserted onto the nub of the fill valve, and isn't split or cracked.
  6. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I won't be able to provide a photo. The problem exists at my mothers house where I was visiting this past weekend (250 miles away).
    I did check the flex tube from the fill valve to the overflow tube and it is not spraying. The spraying is coming from around the top of the fill valve. The fill valve looks like a modern fill valve, but it does have the floating ball w/rod.
    Thanks in Advance,
    Bill
Similar Threads: Fill Valve
Toilet Forum discussions Kohler K-3406 San Miguel Toilet fill valve . . . Feb 1, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Champion Max 4 - Fill Valve Issue Dec 21, 2016
Toilet Forum discussions Need assistance with stuck fill valve on polybutylene piping - possible solutions? Dec 7, 2016
Toilet Forum discussions New Korky 528 Fill Valve looks like its leaking...bubbling Nov 9, 2016
