Fiberglass shower base with compression drain
Discussion in 'Shower & Bathtub Forum & Blog' started by xdeaconx, Mar 23, 2010.
  1. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    I have a fiberglass shower base I am installing in a basement bathroom. I have all the stub out plumbed with 2" cast iron a concreted. I left the length sticking out of the concrete long so I can cut it to length. I am wondering what that lenght is?
    Should the top edge of the pipe be flush with the top of the rubber gasket when torqued down? or should it be below or above that?
    Now that I think about it, I have the same type of fitting for the toliet flange. I guess the same question applies to that as well.
    thanks guys.
  2. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    The shower should be at the top of the rubber. The toilet should be at the top of the flange so the wax will sit on it.
  4. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    thanks for the reply dcelite, will do.
Similar Threads: Fiberglass shower
Shower & Bathtub Forum & Blog Delta Shower Faucet in Fiberglass Shower; Hole Size? Remove Plaster Guard? Jan 31, 2015
Shower & Bathtub Forum & Blog Which Mortar for Bed for One-Piece Maax Fiberglass Shower? Jan 16, 2015
Shower & Bathtub Forum & Blog Replacing fiberglass tub/shower with shower Feb 9, 2014
Shower & Bathtub Forum & Blog Shower Pan (Fiberglass) Install on Wood Floor Sep 8, 2013
Shower & Bathtub Forum & Blog Occasional leak from drain of fiberglass shower unit. Sep 6, 2013
