Fiberglass Exterior Doors
Discussion in 'Remodel Forum & Blog' started by Weaselpolooza, Sep 29, 2006.
  1. Weaselpolooza
    Weaselpolooza New Member
    Sep 11, 2006
    Michigan
    Can Fiberglass exterior door be painted? I have come across some cheap doors, but they are not the color I want.
  2. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    Yes. In fact, they must be, in most cases to keep warranty on them.
    Pete
  4. Weaselpolooza
    Sep 11, 2006
    Michigan
    Actually they are already painted. I would be painting over the existing paint to match my color scheme. Is this OK?
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Go for it.
  6. OldPete
    Jan 4, 2006
    NJ
    Yes. And if you use a stripper or something to remove the paint (and not the kind you find in a night-club, ;)) -- use care since some of them can do funky things to fiberglass.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think paint stripper would be a waste of time and effort on a fiberglass door. You might want to lightly sand the surface, but even that might not be necessary, depending on the paint you use.
  8. jimbo
    jimbo Plumber
    I agree with G.S. This is a straightforward paint issue....surface prep is the key. I wouldn't use any chemicals, not even liquid sandpaper. A little TSP would probably take any sheen off, then I would use a good coat of primer and best quality acrylic topcoat.
  9. indyjps
    indyjps mechanical engineer
    Jun 7, 2006
    mechanical engineer
    indianapolis (fishers) indiana
    ive done them with auto paint, scuff them down, degrease and shoot the paint, you can have it mixed in any color and any amount of shine. use a single stage with a hardener and youre good to go. you can even wax them once a year.
Similar Threads: Fiberglass Exterior
Remodel Forum & Blog Triming Exterior Fiberglass Door Jun 13, 2011
Remodel Forum & Blog Fiberglass exterior door paint issue Apr 7, 2008
Remodel Forum & Blog Radiant Barrier Insulation vs Fiberglass Mar 20, 2012
Remodel Forum & Blog So, I want to to insulate my garage too...plastic supporting fiberglass. Oct 21, 2009
Remodel Forum & Blog Can a 1 piece fiberglass shower enclosure be cut in two and repaired? Jul 17, 2008
