Fiberglass exterior door paint issue
Discussion in 'Remodel Forum & Blog' started by yar02169, Apr 7, 2008.
  1. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    I have an exterior door made by Anderson that doesn't like paint. I have painted, stripped, and repainted the door several times without any luck. Shortly after being painted, the paint bubbles in some areas, and it perfect in others. I have used both oil based and latex paint, and the results are the same. Initial paint preparation included washing the door down with TSP to remove any oils or residual dirt.
    At this point I have sanded the bubbles and repainted the effected area, but the paint (latex) again bubles.
    Any ideas out there?
  2. jimbo
    jimbo Plumber
    A good primer is the requisite first step. Contact a good paint store, or Anderson, for specific requirements. These doors should be paintable.
  4. Squ1rrel
    Squ1rrel New Member
    Dec 21, 2007
    Texas
    Jimbo is right, primer is a good start. Also, make sure you are within the temperature range if you are painting the exterior of the door. Most paints cannot be applied when the temp is below 50 degrees, although some can be used down to 35.
  5. Ian Gills
    Jul 24, 2007
    USA
    I do not have an Anderson door but I used a matt oil paint (Rustoelum) on my fiberglass door to good effect.
  6. elkhornson
    elkhornson Junior Member
    Apr 11, 2008
    general contractor
    New Jersey
    Although expensive a boat epoxy paint will work the best and last the longest. The marine epoxy paints are designed to adhere to fiberglass and their long life is important as sanding blistered paint off a fiberglass door is not really an option and chemical strippers are pain to use.
    John
  7. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    Thanks for the info. Now, to correct the problem, so if I want to persue correcting it I need to remove the current paint. As Elkhornson states, sanding the fiberglass is really not an option, so I will have to go with a chemical removal. Is there a known brand of paint remover that is safe to use on fiberglass? I know the process will be messy, but if I can make the door look like it isn't from a scrap yard, I'm willing to try it.
    Originally I painted the door down in my basement before it was installed, 65°F or so, other coats were done after installation at 70°F+.
  8. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You might have better luck with a heat gun, although you'll have to determine the right temp to use for a fiberglass door.
  9. DIY
    DIY Member
    Dec 24, 2006
    Florida
    door paint issue
    Does this fiberglass door have a simulated wood grain texture to it? If that is the case perhaps that wood grainy texture is holding in greases, oils, dirt etc.. Preventing you from getting the door really clean before applying a primer coat (some doors come with primer on them) then the finish coat. As well, as other have mentioned depending on your weather conditions might cause your prep work to have to be "double good" which might lead also you to a tolerant primer/paint for your conditions.Best of luck to you with your door.
Similar Threads: Fiberglass exterior
Remodel Forum & Blog Triming Exterior Fiberglass Door Jun 13, 2011
Remodel Forum & Blog Fiberglass Exterior Doors Sep 29, 2006
Remodel Forum & Blog Radiant Barrier Insulation vs Fiberglass Mar 20, 2012
Remodel Forum & Blog So, I want to to insulate my garage too...plastic supporting fiberglass. Oct 21, 2009
Remodel Forum & Blog Can a 1 piece fiberglass shower enclosure be cut in two and repaired? Jul 17, 2008
