Fiberglass / Acrylic Shower Stall Drain Install?
Discussion in 'Shower & Bathtub Forum & Blog' started by arjmjk, Apr 17, 2006.
  1. arjmjk
    arjmjk New Member
    Apr 17, 2006
    Just want to confirm the proper way to install this fitting?
    1. Cut PVC pipe to correct height so that flange of fitting is 1/4" under floor of shower.
    2. Cement Flange fitting to 2" PVC pipe.
    3. Locate shower stall
    4. Place cardboard and rubber washer on flange of fitting, (under the floor of the shower).
    5. Apply plumber's putty to male threaded flange (the portion that the strainer is attached to), and tighten into female portion of fitting through shower drain hole.
Similar Threads: Fiberglass Acrylic
Shower & Bathtub Forum & Blog Fiberglass/acrylic tub cracked. any advice? Dec 12, 2011
Shower & Bathtub Forum & Blog Looking for good quality fiberglass/acrylic shower base and sliding doors Nov 2, 2010
Shower & Bathtub Forum & Blog plumbers putty on fiberglass/acrylic tub Jan 13, 2010
Shower & Bathtub Forum & Blog Replacing Acrylic Bar in Fiberglass Shower Enclosure Apr 22, 2008
Shower & Bathtub Forum & Blog Steel, styrene, fiberglass or acrylic ... which is best for replacement tub? Nov 5, 2007
