Fernco with a Lead Pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by scott123, Jan 6, 2007.
  1. scott123
    scott123 New Member
    I've got an elderly plumber who's been plumbing since WWII who, today, just installed a fernco union between a 1 1/2" PVC and 1 1/2" lead pipe. I asked him if the fernco would work with the soft lead pipe, and he assured me it would.
    I just did a quick web search, and, from the couple of sources I came across, it seems that my plumber might be incorrect.
    Is it possible, that with very careful tightening (not tight enough to bend the lead) that a fernco might work? My plumber's the nicest guy in the whole world, so I know he's not BSing, but I'm really crossing my fingers that he's not plain wrong.
  2. Randyj
    Randyj Master Plumber
    1,047
    Alabama
    I've never heard anything against it.... and I would use one if it fit. I don't know what other choices you would have...
  3. Gary Swart
    Gary Swart In the Trades
    7,302
    Yakima WA
    I'm not sure about using a clamp coupling with a lead pipe, but a Fernco which is neoprene with 2 clamps, is not supposed to be used inside. You should be using a banded coupling if and I repeat, if, the lead pipe is acceptable for this type of connection. Stay tuned because there are plumber on this forum that will know the answer to that for sure.
  4. Austin Home Improvement
    Austin Home Improvement All home Improvements
    Kentucky
    fernco
    why didn't your man go a head and take out the rest of the lead pipe all the back to a threaded joint or just take out the hole thing and replace with pvc?
  5. Austin Home Improvement
    Kentucky
    fernco
    By the way, banded couplings are junk. always try to go with glue, or threaded joints. Banded joints leak down the road.
  6. Cass
    Cass Plumber
    5,980
    Banded couplings work fine when installed properly. I have been using them for years with no problems. Where is this going that it can't all be replaced?
  7. solsacre
    solsacre Plumber
    70
    Arkansas
    Cut the guy some slack... when I retire I'll be less into "rip it all out" mode.
    If you can fix it good without much work....... why not?;)
    I'f the line was suported well I'd use a no hub and or "furnco". Threades ar always better... but I've never seen a properly installed no hub, or "furnco" leak... only the ones that are put in a bind.
    A PIPE IN A BIND IS BOUND TO COME APART...:eek:
    If it's not leaking I wouldn't think twice about the repair.
    good luck
    dances-with-pumps
  8. lead drain lines
    If this is a 1 1/2 or 2 inch lead drain line of some nature,
    it takes quite a bit of pressure to bend that
    stuff and its probably going to last for another
    50 - 100 years .....as long as it had support...
    If you can simply put a FERNCO fitting on it
    and keep from getting yourself into troubles tearing out
    the whole lead drain line and god knows what else along with
    it , that is the smart way to do this.... it will last forever...
    I like the FERNCOS over the banded no -hub clamps....
    they go on very easy, and are flexible and
    much more forgiveing...
    I like to put "glue" on the lead pipe
    and on the inside of the FERNCO fitting......then tighten the
    whole thing down........you relaly have to work to pry that joint
    apart down the road...
  9. scott123
    scott123 New Member
    It's a lead drain pipe running through the kitchen ceiling, coming from a 2nd floor bathroom sink. Removing the entire pipe would pretty much involve trashing most of the kitchen ceiling.
    It's well supported. The lead pipe runs through a hole in a joist and the fernco is only a couple inches away from it. The PVC side is only about 8" until you hit the L running up to the sink.
    Thanks everyone, for all your replies. I feel better. Right now there's a small hole in the ceiling which I'm going to leave open for a while in order to monitor the union. I may end up pulling down the kitchen ceiling and replacing the entire run- We'll see.
    Regardless of what direction I take, this has been very very helpful, thanks again.
  10. Randyj
    1,047
    Alabama
    If that's true then there's alot of extremely large buildings in a heap of trouble. Lots of places require it by code. If you are the one putting them on and they are leaking then you might need to check out your technique and be sure you are using a torque wrench. Pretty much the standard when transitioning from one type of pipe to another.
  11. molo
    molo New Member
    840
    cold new york
    Why did you have to do the repair in the first place? Was that the only way he could get to the toothpaste cap in the bathroom sink drain? :)
    Curious to know,
    Molo
  12. scott123
    scott123 New Member
    :) no, no toothpaste cap.
    The lead pipe started to split at the connection. It was a strange connection- at the turn of an elbow. I'm sure a plumber could describe it better, but I'm not a plumber.
    It's just a thought, but an embedded vector drawing program would be great for a forum such as this (or, if that's not possible, maybe a pipe font)
Similar Threads: Fernco Lead
Plumbing Forum, Professional & DIY Advice, Tips & PVS Repair Coupling VS. Fernco Coupling Apr 20, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Fernco Donut Tight-ness question (maybe too loose?) Mar 12, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Fernco couping question Jun 2, 2013
Plumbing Forum, Professional & DIY Advice, Tips & slow set pvc cement or glue for slip fitting vs. fernco or no hubs Jan 10, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Fernco and Mission fittings? Questions? Jan 25, 2012
