Faulty sprinkler valve
defreib
Can someone tell how to locate a sprinkler valve that is buried some where in my front yard?
Thanks in advance
PEW
DIY Senior Member
Usually all the zone valves are together, often right outside the house. Sometimes they are covered with a green plastic cover, which grass or mulch can hide. You may want to trace where the control wires go from the timer.
Witching for pipes
You may be able to locate by witching for it.
I take a coat hanger and cut two el's from it.
I re-bend if needed to create a right-angle bend.
Hold each one in a hand loosely and walk around the yard.
When the wires go over a pipe, they will point toward each other.
At that point, the wires are inline over a pipe. :)
Valve
I am not a believer in "witching" so it never works for me. I borrow an electric wire toner/tracer and follow the wire to its end which is where the valve will be.
twstore_1814_903942
Cable locator. Connect the tone generator to one end and find the other end by moving the tone detector near the other end. The easiest way to match cable ends at hundreds of feet away or to find a single cable in a bundle.
basie1234
Sprinkler Valves
I have had two of six zones out for over a year and couldn't find the valves. I had a contractor out for some maintenence and he couldn't find the valves either. Today I rented a tone generator for $15.00 for half a day, found the two zones. One in 15 minutes, the second an hour and a half (and about six dry holes) later. Thanks - the tone generator solution worked great.
