Faucet broke
Discussion in 'Shower & Bathtub Forum & Blog' started by leebee, Apr 2, 2014.
  1. leebee
    leebee New Member
    Apr 2, 2014
    virginia
    I have a American standard colony series 6 shower diverter
    While I was un screwing my faucets the actual head of the faucet broken off
    I have purchased a new stem for the diverter but I am reluctant to try and unscrew the rest of the diverter as it looks like to whole thing might be corroded on
    any ideas on how to get the old out and put the new in please se attached pic
  2. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    It should come out with little problem. I service an apartment complex with dozens of the Colony faucets and have never had a problem removing a stem. Nice thing about the Colony is you do not need special wrenches as the wrench flats on the stem are exposed. After you remove the stem, bring it to your plumbing supply store and have them match it to a new stem and handle.
    Be sure to apply silicone grease to the threaded portions of the new stem, the handle splines and handle screw prior to installing it. You will be doing a favor for yourself or the next person who services your valve.
  4. leebee
    leebee New Member
    Apr 2, 2014
    virginia
    thanks for the reply as I said I am reluctant to use force as we have tried using flat wrenches to try and remove the stem and as you can see the old splines have broken off in the handle and I am having trouble trying to find a replacement handle any ideas from you on that subject please
  5. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    In my area Home Depot stocks both the stems and the handles in the generic Danco brand.
  6. leebee
    leebee New Member
    Apr 2, 2014
    virginia
    Hi Everybody,
    I have tried to take this diverter off with a loose wrench as SHR suggested but it will not budge any other ideas I really need to get this diverter out so I can use the shower/tub again this really needs attention ASAP thanks in advance
  7. hj
    The retainer nut will unscrew easily, but pulling the diverter our COULD be a problem. I once had one that took a couple of hours to work it out and remove all the pieces.
  8. leebee
    leebee New Member
    Apr 2, 2014
    virginia
    thanks it still does not solve my problem though! some advice would be handy
  9. hj
    How much more advice do you need. You have to REMOVE the diverter and replace it with a new one. That is all the help we can give you unless we come over there and do it for you. As for the piece in the handle, you loosely screw in a "hollow head cap screw" and then drive the stub out with a hammer and drift pin punch.
Similar Threads: Faucet broke
Shower & Bathtub Forum & Blog Moen tub faucet cross member broke Dec 3, 2016
Shower & Bathtub Forum & Blog Stripped Screw & Broken Extractor - Shower Faucet Jul 17, 2016
Shower & Bathtub Forum & Blog Gerber Single Handle Shower Faucet Broken Oct 21, 2009
Shower & Bathtub Forum & Blog Broken O-ring?: Water leakage at the handle faucet, then suddenly no water at all! Apr 6, 2008
Shower & Bathtub Forum & Blog broken shower faucet handle is stuck Feb 18, 2008
